Can’t watch movies on YouTube though JavaScript is enabled
I have this problem and I don't know how to fix it. My windows is Vista, Internet Explorer is 7. My JavaScript is enabled, Adobe Flash Player is updated, yet still I can’t watch the movies on YouTube.
It says "Hello, you either have JavaScript turned off or an old version of Adobe's Flash Player"
Any clues?
Best Answer by Reco Toldo
Answered By 0 points N/A #151369
All you have to do is remove all existing version of flash player from your computer and then reboot.
Next try to get Internet Explorer 8 and Net Framework 3.5 from Microsoft and install.
You also need to get a new version of Adobe Flash player and install and then Reboot.
I hope this will help you.
Good Day!
Answered By 0 points N/A #151370
Good day,
Maybe you must update your Internet Explorer and also Adobe Flash Player,and restart.
Jacksonn Maria
