I have a 64 GB LTE iPhone 5 that has Dual-core 1.2 GHz CPU, PowerVR SGX 543MP3 GPU and iOS 6.1.2. I'm thinking of purchasing Tansee 5.3.1 and I was wondering if the Tansee iPhone transfer contact software can export an ANTC file format?
Can Tansee iPhone transfer contact export ANTC?
Using Tansee iPhone Transfer Contact Software, iPhone users can back-up their contact list and contact's photos and export them on their computers in two file formats. These formats are ANTC (.antc) and Text (.txt). They can also secure their files with a password for privacy purposes. Before transfer, you can choose if you want all your contacts to be moved or just single contact.
Tansee iPhone Transfer Contact can provide you:Â
1Â Backup contacts on iPhone memory to a file.Â
2 Export two types of file format (Antc file, Text file).Â
3Â Backup iPhone Contact s Photos. Â
4Â Export full screen of iPhone contacts Photos.Â
5 View Contacts in Text file format (.txt) or ANTC file format (.antc) on PC.Â
6 Password protection support (ANTCÂ file only).
Using Tansee iPhone Transfer Contact all iPhone user can backup the contact and contact s photo to computer. With Tansee iPhone Transfer Contact, you can transfer the iPhone contact to computer as a txt file or a ANTC file. Before the transfer, you can choose to transfer all contacts or a single contact. In ANTC file condition, you can protect the file with a password to keep your privacy.
You can download the software from this link : https://www.windows8downloads.com/win8-tansee-iphone-contact-backup-arquxenl/download.html
ANTC file can display all contacts in Tansee iPhone Transfer Contact window. It can also copy to .txt file and .csv file. ANTC file format supports strong encryption password protection method, so ANTC file is safe for personal privacy if you provide a password to the file. ANTCÂ is developed by tansee.com for storing iPhone contact data. Therefore, Tansee iPhone can transfer contact in ANTC file format.
