I have noticed that my desktop's speed has become slow. I'm thinking that I have to clean and fix the registry to bring it back in top shape. Can Uniblue 2 scan, fix and optimize my system registry? I'm on Windows XP 32 bit Sp 2. Thanks in advance.
Can Uniblue 2 clean my registry?
Hi Albert D White,
Your decision is right, Uniblue 2 software can fix and optimize your system registry. Uniblue 2 software's features-
·        This software will deep scan your registry
·        Then identify your problem
·        After identify it will remove harmful registry
·        You can also defragment your registry by this
Above all bullet points represent the features of Uniblue2. So, you can use it but it is not true that your PC will be super fast. Your PC will be faster than before but not super faster.
Here's a link if you want you can learn more from here-
http://www.uniblue.com/product/pc/registrycleanerkit/
Thank youÂ
