Can using VPN transmit a virus?
I use a VPN connection at times for work, and I am being told the network has a virus and do not connect until it is cleared. Can a virus on the work network be transmitted through the VPN? I need to get my work done but I don't want to get the virus and I wanted to be sure I had the correct information. Thank you.
