Hello experts,
Can VBS read exchange mailbox? I am not that good in vbscripting that is why I am needing some of your help if VBS is capable of reading exchange mailbox or any other kind of feature that the VBS has. If there are some chances that it is possible can you give me a step by step process on how can this be done?
Thank you.
Can vbs read exchange mailbox?
Hi Curtis,
VBscript can possibly exchange mailbox. It has a lot ways and a lot of codes that can do that. VBscript codes can find in different forums. Some are complicated and some codes are simple. Kindly check this forum:
VB Exchange Mailbox
this may answer your questions.
If you are confused with the codes and its uses:
You can check a tutorial for that like this Link below:
Visual Basic Tutorials
Hope it would help you a lot with your concern.
Thanks and more powers.
