Can we change the default mouse pointer in blogger?
Just wanted to add spice on my blog and I thought that changing my mouse pointer into something attractive would make more appealing. Is this possible?
Answered By 0 points N/A #80435
Of course, it is possible to change default mouse pointer in blogger. You just need to know something for change the mouse pointer that allows many singular options. If you know how to change mouse pointer by using html code then by doing experiment more you can create better pointer. Also you can make your own mouse pointer yourself and you just need to know a program like GConvert to create .cur files and have place to upload this .cur file. Also, you can create a graphic file using GConvert and Gdgsoft and to create your own pointer you must save it as a .cur file.
Answered By 590495 points N/A #287055
In Microsoft Windows, changing the mouse cursor or mouse pointer is very easy. But if you have a website such as Blogger, modifying the mouse pointer is a different thing. Though this task requires editing a certain file, the process is easy. To change the mouse pointer on your Blogger website, first, log in to your Blogger account. Next, go to “Template” and then select “Edit HTML”.
Look for the “bskin” tag in the HTML document and then above it paste the following code:
body{
cursor: url(Your-Cursor-Image.png), auto;
Note: you need to replace “Your-Cursor-Image.png” with the URL of the cursor you will be using. Once you are finished, save the changes on the template. And that’s it. You have now customized the mouse pointer on your Blogger website. To look for mouse pointer images, you probably want to visit Cursors-4U.com.
On the other hand, if you don’t know how to get the URL of the image, visiting How to Upload Images to Posts in Blogger might help.
