Can we connect Samsung Galaxy S4 to iPAD Air to transfer contacts
Can we connect Galaxy S4 to a iPAD to transfer contacts etc?
I have this new iPAD and want to copy all of my stuff from Samsung Galaxy S4 to my iPAD Air
I will need help on step by step
Answered By 0 points N/A #199297
Hi Poddenvo,
Yes you can connect GALAXY S4 to iPhone just go through with be below steps for simply to copy all of your stuff from Samsung Galaxy S4 to my iPAD Air
Step I: Install Wondershare Mobile Trans on your PC after downloading, and then just connect the two phones on your computer with the program via USB cable. It will enable to be copied all of your stuff from Samsung GALAXY S4 to iPhone directly.
Step-II: After detecting these two phones, this Wondershare Mobile Trans will display main window shown as “Source” and “Destination” after then you can active “Flip” button and marked the desire stuffs you want to copy from your Samsung GALAXY S4 to iPhone directly.
Click on the Start Copy button to be copied all selected stuff.
After competing copying data just click OK to end it.
Note: It will never delete any file on both GALAXY S4 and iPhone directly unless you check “Clear data before copy” option.
