Can we control Windows 8 from a mobile phone?
What are the steps and gadgets needed to achieve this?
How can we do it and step by step info is needed
Best Answer by Wagner Desantiago
Answered By 5 points N/A #163332
Hi!
Yes, we can control Windows 8 from a mobile phone, especially by using Android phone.
First of all, you need to download Windows 8 server app for your PC. This can be done by downloading it anywhere in internet,
Gadgets needed are of course your PC, mobile phone ad Windows 8 server app.
Below are steps to link together your PC and mobile phone:
1. You'll see two buttons, first is option and second is help button.
2. Next, you go to option button. There, you must click customization option.
3. Refer to your mobile phone, look for auto connect button. You must click on it so your mobile phone can control Windows 8 automatically.
After getting this app, you should read this on how to use this app:
1. There are three buttons which are panic button, calendar button and start button.
Answered By 5 points N/A #163333
Hello Qasim suliman,
Yes you can control your windows 8 pc from mobile. And it's easier than ever. Windows 8 controller is an app which is available at windows store, Playstore and coming soon at IOS. This app lets you to do regular computer management works. Here's how it is done –
1. First download it from windows store or Playstore (only applicable for this two).
2. Now install it.
Now after you installed it, you can see it is incredibly easy. Only two buttons are there Options and Help.
3. In option menu you get a good deal of settings.
4. Press start and then Auto connect. Now it will automatically connected your phone and PC.
5. Once you get connected it's all easy. Move your finger to start. And in the bottom left corner click start and control your PC!
Hope it helps!
