ewushm11
Posted on - 11/20/2013
Can we export Google Calendar to Outlook Calendar?
Or
Can we get the Outlook Calendar to Sync with Google Calendar?
I have huge scedules and want to do it safely
So please give me the exact steps for both ways
Hi
To export the calendar you can create a ‘Calendar Snapshot’ or a copy of the calendar. This does not continually update, but just creates one copy of your calendar. To complete this you will need to log into your Google account, click ‘calendars’, under calendars click the arrow button next to the calendar, click on calendar settings, select private address, select ICAL, for the calendar address click the address of the calendar, select OK and your calendar will then import into Outlook.
For your calendar to automatically update from Google to Outlook, you will want to follow these steps: log into your calendar account, select calendars, select the arrow button, select calendar settings, select private address, select ICAL, select the internet address and select copy. In outlook click on tools, then account settings, select internet calendars, then ‘new’, paste the web address that you previously copied, click add, under the folder name type the name of the calendar and then select ok.
To import a calendar from Google Calendar into Outlook:
Click the down arrow next to the desired calendar in the Google Calendar My calendars box.
Select Calendar settings from the menu.
Click on the ICAL icon under Private Address: with the right mouse button.
Select Save Target As…, Save link as…, Download Linked File As… or something similar depending on your browser.
Save the "basic.ics" file to your Desktop or Downloads folder.
Double-click the "basic.ics" file you just downloaded.
If the file does not open in Outlook:
Open Outlook.
Select File | Open | Calendar… from the menu.
Find, highlight and double-click the downloaded "basic.ics" file.
Delete the "basic.ics" file from your Desktop or Downloads folder.
