Can we extract rar on server?
Hi guys,
I wonder that can we open or extract rar on server, which uses windows 8 r2. If so, we use some software or scripts.
Thanks
Answered By 0 points N/A #179130
You need to use a program to extract your rar files. You can download Winrar to extract your files. It is free and is easy to use. You can download it at http://download.cnet.com/WinRAR-32-bit/3000-2250_4-10007677.html
Another choice of software for you is WinZip. It is basically the same as Winrar. It also has a free trial version that you can use. The downside is the trial version lasts 21 days unlike Winrar which lasts 45 days.
https://download.cnet.com/WinZip/3000-2250_4-10003164.html?tag=contentBody;pop
