Hi techyv,
Can we import a project for paint in java? I have too many drawings like a simple computer interface in my paint project collection, I am just wondering if I can import those files in my java system and set it as a graphical user interface. I need some advice and accurate information.
Hoping for your help. Thanks.
Hellow Janet,
I have confirmed about your problem. I want to illustrate simple java program for painting. After utilizing the program your programming capacity will be reached to the point where you can create any canvas of scenery with mental color.
Before entering into the code you have to make 16×16 GIF for each of colors. It must be saved as the name of GIF in the code.
The code is attached to this solution.
Regards
Shifflett Laurel
Dear Janet Campbel,
I will give you a nice solution for your problem. If you want to change the color and shape you need to set the paint method. As an example, I want to say that you can use the color code. For a red color you can use .RED code. If you search on Google you will find many color codes for different colors. Hope it will be helpful for you.
Thanks and Regards,
Calderon Nicholas
