Can we perform a cut paste PDF page software?
Hello fellows,
I am just curious if we can edit a PDF page with exactly like Microsoft Excel and Microsoft Word application packages, this is very important for me.
I have to be aware about PDF software abilities for some important business transactions online.
Thank you.
Rebecca Green.
Best Answer by Sharath Reddy
Answered By 0 points N/A #173713
Hi Rebecca,
I can help you with this query, Indeed you can perform a cut-paste with Adobe PDF.
This is what you will need to do to fix that issue;
When you open your Adobe PDF file, go to the 'Tools' option in the top left of your window and Click on Select and Zoom -> Select tool.
Different tools for editing
When you click on 'Select' tool in the toolbar, you can change the cursor. You should now be able to achieve the text to cut and paste.
I hope this solves your query.
Answered By 590495 points N/A #173714
If you simply need to copy and paste the texts contained in a PDF file then the post above will surely help you.
Simply follow the instructions described above to perfectly copy the text contents of a PDF file.
But if you need to do a different job besides copying the PDF file’s texts, there is a website where you can find the tools you want.
You may visit. Some of the PDF tools they offer are listed below.
PDF Merger and Splitter
  • PDF Merger
  • PDF Split
  • PDF Content Splitter
  • PDF Size Splitter
  • PDF Scan and Split
  • PDF Manual Split
  • PDF Page Size Split
  • PDF Page Cut
  • PDF N-up Page
PDF Modifier
  • PDF Watermark
  • PDF Label
  • PDF Number Pro
  • PDF Explorer
  • PDF Rename
  • PDF Preview and Rename
  • PDF Preview and Move
  • PDF Text Replace
  • PDF Scan Optimizer
  • PDF Page Master
  • PDF Page Cut
  • PDF Page Crop
  • PDF Filler
  • PDF INFO Changer
Answered By 5 points N/A #173715
Hi Rebecca Green,
Many process of PDF to word converter, online or offline. Converting online at the following address you can use.
https://www.pdftoword.com
http://www.pdftoword.org/
If you want to download the Software from the following address, Click the web site and download this software and install your PC.
Thanks to your Question to techyv.
Hope it helps.
