Can we put insert button in the context menu
i have a question that there is eject button in the context menu but i want to put insert button .Is it possible to do so?
Definitely yes,
We can put an insert button when we right click on CD/DVD icon though initially we are able to see only eject button.This can be done easily .No, hard work is required
Follow the instructions as given in
How to Add Insert Option in CD/DVD Drive Context Menu in Windows?
Hello Airmate,
It is very disgusting to insert disc pressing the button on the CD/DVD ROM. We can open it through Windows but can’t close it.
1. First, download the zip file. Extract it using 7-zip.
2. From the extracted files, copy the DLL file into the following directory:
C:WindowsSystem32
3. Then, open the registry file. Click “Yes” if prompted.
Now, you have got the “Insert” option.
Also, you can use a small software. It is called WinEject. It is a small file that supports hotkeys to open and close drives. Also, it has support of managing multiple CD/DVD ROMs.
