Can we put meta tags in every post in blogger?
I've been studying meta tags and seo for a week now. I noticed that if you are using a blogger.com as your host, putting meta tags is limited. Now, A thought came out to my mind that if we can put meta tags in every post we can use its power. Is this possible?
Answered By 15 points N/A #129203
Hi Maria,
For sure it is possible to put meta tags in every post in your blog. Just use the following procedure:
Go to design and choose edit html. But before that create a backup of your template in case the changes you make end up being tragic.
Look through the template to find the following code: <title><data:blog.pageName/> | <data:blog.title/></title>
After finding it, paste the following code just below it: <meta expr:content='data:blog.pageName' name='description'/>
That is it. You can now enjoy a few more hits on your blog.
Hope you are helped.
Regards.
