jim bbauman
10 points
Posted on - 01/11/2013
Hello techyv,
Can we set or change sound theme? I just switch with Windows 7 64 bit operating system and I would like to apply a sound for a specific wallpaper or background theme. How can we configure the settings? Share with me the procedure. I am willing and eager to follow instructions.
Expecting some help from you guys. Thank you.
Hi Jim, some of the sounds that our computer use are defaults of the background that we are also using. But what i do in mu case, if ever I want to change the sound that my computer is using I just change the setting of the sound in my system.
To do so:
click the start button.
Type "sound" on the search box.
click "Change sound card setting" and it will bring you to…
where you can change the sound settings.
