Can we use a Apple keyboard for my Windows System?
If yes how can i sync them?
Steps to connect them
What could be missing in the keyword thats needed for a windows system?
Yes Windows Vista, Press a modifier key with a character key. Like press the Command key and the "c" key at the same time copies whatever is currently selected into the Clipboard. It work with Windows 7, however the wireless keyboard would go to sleep all the time and very quickly. Apple allow you to download this update after installing the Boot Camp drivers on mac.
Hi.
Yes. You can use Apple peripheries on Microsoft Windows. Apple keyboard is an USB keyboard. Plug it in your PC and you can start using it. Apple keyboard has good build quality, it is comfortable to type on, it has low profile keys. For Apple keyboard you will also need to remap some keys. On picture below are pointed differences between Apple and Windows keyboard.
Queen Norman
