Can we use css in customizing your blogger page?
Just wondering if I can use css to customize my page in blogger. I'm not satisfied on how it looks. Can someone help me with this? I know a littlebit about css so if css is compatible in blogger that would be great.
You can change your blogger css template by going to: Design, then click Edit HTML. Then you will see the Edit Template box content which filled up with html code. The css code is between code:
<Head> and </head>
That's the css code. And rather you find difficulty in creating your css for your template, I suggest you to find a template design for blogger in search engine. The keyword could be like this for example: blogger template 2011
Those templates were made by designer outside blogger. After you find the template you like, download it, usually it is a zip file. Extract that zip file, and its content must be formatted in XML.
Now, go back to Edit HTML page on your blogger, then backup your template first before you change to a new template. After that find 'Upload a template from a file on your hard drive'.Â
Use Preview (below the html content box) to see your new blog. If you satisfy, then click save. If not satisfy, click Clear Edits.
