Can we use Smart sheet offline
Hi, Can we use Smart sheet offline? If so how can we set that? I am very new to Smart sheet application. When I try to explore it, it is show that their website is offline is under maintenance.
Smart sheet application is provided by Google by using cloud technology so called software as services (SAAS). In this sort of services you store and update your sheets or any other application data remotely. You may fill sheet in offline mode but you have to connect with cloud to update you sheet.
Thank you
Dear Friend,
It looks like Google drive you Already have the sheet on your computer saved with the last changes you made on it, and this changes are save online, but if you make changes on this sheet without connecting to the internet, this changes will be saved only on your computer and if you opened your smart sheet at this moment from another machine you will not find these changes until your first computer you made the changes on it connected to the internet.
