I have two widgets which are coded in javascript and I wanted to use in same website but I don't know how to do it. Is it
possible to use two widget in the same website.If yes, please provide some suggestions. Thanks in advance.
Can we use two JavaScript widgets in the very same website?
Yes you can use two widgets for two JavaScript code but you must use it different url link. Same website is not any matter you can use many script not only java but also css, php and mysql. You will use the link location that means where your javascript file is.
Which type of website you use? CMS and static website JavaScript using system is so different. I have presented a sample in above which can use commonly in cms and static website. But if you want to customize your javascript function you must have the idea about javascript.
