Hi All,
I have recently bought iPad 3. Want to know about using the camera and MSN Messenger. Is it possible to use iPad Messenger webcam? An early reply would be appreciated. Please also tell how doing that?
Can we use webcam and messenger in iPad
Possible, if you have yahoo app just sign in to your account. On the left side, you will see lists of contacts. If you would like to set your status: visible or anything you want just choose it.
You can add or send a message to your contacts, type in your message then click send or if you want to put some emoticons, send pictures that you already have or take a picture and normally If you send picture the process is slow, you have to wait on it for proper sending, you can also video chat and call and lastly you can also send the URL. If you want to stop messaging, and want to clear conversations then go on. Don't forget to log out after messaging.
Steele Ney
Yes you can, as iPad3 has a front facing camera and a rear one also. But usually the front facing camera is used for video calls for a variety of videos-chatting apps including Face Time, Skype, Yahoo Messenger, Fring, Seen, MSN Messenger and VTOK.
For use webcam and MSN Messenger in video calling then first create an account on MSN. After successfully creating an MSN account and getting a username in MSN Messenger, you have to download MSN apps from iTunes for using it on iPad3.
You can get it on:
https://itunes.apple.com/us/app/video-messenger-for-msn/id411620919?mt=8 (Free)
Or
https://itunes.apple.com/us/app/video-messenger-for-msn-pro/id447750034?mt=8 (Paid one about $0.99)
After you successfully download the apps in your iPad from the iTunes website then launch MSN in iPad. Login into that app. Add your MSN contacts like your friends, family etc. MSN IDs and as your friend login into MSN from any other device, you will see his/her status in green online signal. Just touch or swap on it and touch on video call option.
