Can we use xp software mover to move an installed game
Hi
I have installed game in my C drive. I currently I finished the half of the game and now it has low disk space in C drive. I need to move this game without playing in from beginning. Can I do that with XP software mover?
Thank you.
Best Answer by RANDOLPH Rosa
Answered By 0 points N/A #149325
Hi Mackenzie Jacobb,
You can do it using Files and Settings Transfer Wizard if you want to move it to another computer. Or you can just find the folder that your games used to save data then just copy and paste it to the other storage and then, when you move your game you can paste it again to place where got it and overwrite the other file.
Answered By 10 points N/A #149326
If you use the steam mover then you can easily move installed games. It creates a junction point in the directory. Steam directory is appropriate to move any folder or software. So, by using that you can easily move anything. I think now you are fully clear about steam mover.
Answered By 5 points N/A #149327
“Hello,
The answer to your question is yes. PC removers act as third party that facilitates transfers of data from one computer to another safely. Flash disks are the best since they do not allow scratch to the data unlike CDs therefore they can not interfere with the data.
