Informantx
10 points
Posted on - 08/07/2011
My computer crashed 2x this week because I deleted some files that the OS need. I'm trying to save some memory and not being a computer savvy, I accidentally erased important files.
Is there a way for Windows to automatically repair errors whenever it sees that there is a corrupted file in the registry? Though there are a lot of possible problems, the errors are pretty much the same and I know that it will be easy for Windows to tell what the specific problem is.
I think it will be very helpful if Windows would atleast warn customers that the deleted file was necessary for it to function properly.
Can Windows Automatically Repair Errors?
Windows can repair files using Chkdsk. Chkdsk is a command line tool that checks for problems and if there is any tool will repair them if possible. To use it you must log in as administrator.
Go to Start, click on Star button and then click Run. In Open type cmd and press Enter. Choose one of these procedures:
To Run Chkdsk in read only mode, type chkdsk at the command prompt and then press enter.
To repair errors without scanning bad sectors, type chkdsk volume:/f and press Enter.
To repair errors, find bad sectors and recover information, type chkdsk volume:/r and press Enter.
It is possible to recover some of your windows files but not most. You can try in your case is it possible or not to do this just restart your computer and then press ON key after this while booting press F8 several time it will show some options and you have to select the recovery option under all options this will check the files of your windows and will repair them all. But in case your windows files are not able to recover then you don't need to install a new window you can just repair your window from the CD or from the source you install the window. When you will start installing windows it will show repair option and you need to select it after this it will restore your window to the previous state.
Also you can try a system restore point in safe mode and it may be the solution in your case.
Tasnuva
It is so simple to recover windows file. You can try in your case is possible. Windows can repair using chkdsk.
It is a command line tools which checks for problem. I you want to use it you must log in administrator.
If you recover your file you just recover your computer. And then press key F8 several time it will show some
option and you just select recovery option and finally this will check and will repair them all. Another way
Go to start ,click on start button and click Run and type cmd and press enter and choose these option.
1. To Run chkdsk read only mode,type chkdsk command and press enter.
2. To repair error without scanning bad sector type chkdsk volume :/f and press enter
3. To recover information type chkdsk volume:/r and press enter.
If you have another question ask me honestly.
Thanks
