Can you generate eBooks using JavaScript or not?
Is it possible to generate eBooks with JavaScript? If I want to enhance my e-magazine by adding pictures and texts, will I be able to update my eBooks that relies on JavaScript?
Hi Harris Martin,
Yes, it is possible to generate eBooks with java script. You just go through this site and get all the steps to be followed.
If you are new to JavaScript programming and you want to learn how to code it so you can apply it on your eBooks then visiting an online tutorial would greatly help. One example of an online tutorial is W3Schools.com where you can easily learn to do the JavaScript programming easily. Visit them at JavaScript Tutorial to begin your online tutorial.
JavaScript is the scripting language of the web and is being used by billions of web pages all over the world to add functionality, communicate with the server, validate forms, and others. Here are some of the methods you will learn from the website:
JS Tutorial
