Can you give me some advice on how to fix this?
I’d like to default my home directory because I haven’t done to update my gnome/wheezy after I find the gedit save dialog and open dialog that defaults to “Recently used”. I also checked this to other computer and the wheezy and the dialog is still the same. I also tried to search some fixable applications from gconf editor but still there’s no result. Can you give me some advice on how to fix this? Or it will not be fixed anymore?
Answered By 0 points N/A #83345
Have you checked the network settings? You will need to go to the YaST and check that your computer is part of the network that you are on, check the domain membership settings. The problem may be occurring because the computer you are using is not part of the domain that you are on. Once you have checked and changed the settings accordingly, you will need to restart the computer for the settings to take effect.
Also, in case the computer is on a network that uses static IP addresses, you will need to make sure that they have been configured correctly, because wrong IP addresses may be the cause to that problem.
-Mathew Stone
