plantinta
Posted on - 10/04/2012
I have been looking around, and I was wondering, do you know what is the best CMS for Phoenix Emulator? I tried RevCMS but IÂ had problems with it. I like novaCMS but it doesn't have housekeeping what are the Top CMS with versions in your opinion?
Thank you.
Can you give me the Top CMS with versions?
Hi Plantinta,
I have seen a linking site that maybe a helpful one in finding the best solution to your problem. I have attached it below:
CMS Version
You may also like this forum:
pligg Forum: Pligg CMS Releases
Hope that it would be a helpful enough.
Thanks and more powers.
You want to know what is the best CMS for Phoenix Emulator?
I suggest you this way
RevCMS, and Phoenix Emulator both are top one. But you should not  use to Xampp, use IIS it's a lot safer for you. But when RevEMU doesn’t work then use it.
RevCMS is very easy to handle it I mean user friendly, but you have to learn PHP to make mass edits. Coldfusion is also  easier to handle.
