Can you help me to get Ajax image zooming code with PHP?
I need to use many pictures with high quality in web. Because if I use Ajax image zooming code with PHP, anyone can see them in zoom mode. But I have no idea in Ajax PHP code. Where is the best Ajax image zooming code with PHP?
Answered By 50 points N/A #181773
Hello, Kristen
Hope you are fine. Don't worry , hope your problem can be solved. Let try it
<!– Put the placeholder DIV where ever in the <body> –>
               <div id="test">This id a placeholder DIV</div>
               <script type="text/javascript">
               // Create new object
               var ajaxZoom = {};
               // Define the path to the axZm folder
               ajaxZoom.path = "/axZm/";
               // Define your custom parameter query string
               ajaxZoom.parameter = "zoomData=/pic/zoom/fashion/some_image.jpg|/bilder/ordner1/test.png&example=8";
               // The ID of the element where ajax-zoom has to be inserted into
               ajaxZoom.divID = "test";
               </script>
               <!– Include the loader file –>
               <script type="text/javascript" src="/axZm/jquery.axZm.loader.js"></script
Otherwise you may click here to learn more with example
Hope you will get your answer.
