Can You Make A Older Printer Wireless?
I have a work horse of a printer that is a HP laser. I want to be able to use the new functions of our laptops, smart phones to print wireless. How can you change a printer to become wireless or is there something I can hook to it to do this?
Answered By 0 points N/A #192524
Hi Patricia C Lahr
Yes you can, there many available hardware that changes the setting of your printer from USB to print or Print air means that you can connect your old printer via WiFi without any cable connection. This is one example of the hardware that I was talking about. A Wireless Print Server Simply place your printer in the place that’s most convenient for everyone who’ll be using it, then plug it into the wireless print server. TP-LINK TL-WPS510U 150Mbps Wireless Print Server, USB 2.0, and Detachable Antenna check the Site for more info regarding on this
check the Site for more info regarding on this hardware.HERE
