Hi techyv,
Can you name some wordpress direct plugins? I need some specific plug in names for wordpress as well as the use and importance of those plug ins. Sometimes we have to put some plug in to enhance a development software’s performance.
Hoping for your help and kind consideration.
Can you name some WordPress direct Plugins?
Good day Amanda,
Here are some of the plug ins that you requested. Hope it helps.
BBpress – It is a forums software. Made the WordPress Way
Jetpack – It can supercharge your wordpress site with powerful feature. Though it is only available to wordpress.com users only.
WP super cache – It is a fast caching engine for wordpress that produce static html files.
Hotfix – Fix unofficial selected wordpress bugs, so you won't wait for the next wordpress core release.Â
Hope this helps. thank you and god bless
Hi Amanda,
Here is a list of some direct WordPress plug-ins:
1. WordPress Database Backup is a backup WordPress MySQL database.
2. All in One SEO pack, which is SEO for WordPress blogs that is out-of-the-box in nature.
3. Conditional CAPTCHA asks the commenter to complete a simple CAPTCHA if the spam detection plug-in thinks that the comment is spam. It currently supports Akismet and TypePad AntiSpam plug-ins.
4. Donate Plus has PayPal integration, donation forms, a recognition wall, a total donation tracker and so on.
5. Events Manager allows you to specify the location, town, province etc. in order to manage events.
6. Exclude Navigation Pages is a checkbox on the editing page you can use to exclude primary navigation pages.
7. Hana Code Insert lets the user easily insert complicated HTML codes and JavaScript codes.
8. BulletProof Security prevents ALL XSS and SQL Injection infiltration attempts. It protects wp-config.php (along with .htaccess protection) and .htaccess security files activation (One click). It allows HTTP503 (Website under construction) activation and so on.
9. Code Markup displays <code> blocks nicely by filtering (still allows formatting).
10. Google Analyticator enables Google’s Analytics by adding JavaScript codes.
11. PHP Shortcode allows running and embedding PHP codes in posts or widgets with shortcodes.
12. Shopp is an e-commerce solution.
13. YouTube Embed is used to embed YouTube Videos in WordPress.
Hope that these will be useful. Cheers!
