I want to use USB VPN software for networking. I never used one before. I will like to have recommendations about USB VPN open source software. How can I effectively launch the USB VPN to other computers so that I can work with them as LAN?
Can you recommend me USB vpn opensource software?
Hey James Craigos,
You have requested standalone VPN software that can be installed into the USB device (USB Stick, USB Token or Smart Card) so as to make the desired computer connected to the VPN server via tunneling without any hassle and without any complex configurations etc.
Most organizations nowadays tend to use their company specific VPN client configurations. You must have admin rights to install and use the VPN configurations on all the computers you want to use because it involves modifications in the routing tables to your internet connection. The most commonly used VPN USB Softwares are below:
Surfbouncer
Linksys
Tomato USB
Checkpoint
Virtual Machine VPN (great tool for newbies)
OPENVPN
LogMeIn Hamachi
You can watch the demo of a USB VPN Software (offered by The Green Bow)
IPSec VPN Client software with USB Drive
