jessielucyy
30 points
Posted on - 04/05/2013
Hello! Can you and is it safe to run two or more installations at the same time on a personal computer? What part of the computer memory and otherwise are highly used during the installation process and how does it affect the general performance of the computer at that time? Thanks big time.
Can you run two or more installations simultaneously?
Hello Jessie,
It is possible to do so but there maybe times when conflict may occur as both installations may try to write in the same directory at the same time. This can result in a failed installation and bad registry. The computer's central processing unit is highly used during this process. I strongly suggest that you install applications, games, etc one at a time.
Sincerely,
Luz M Terry
