Can you share some specs about flash drive 303b?
Hi Max,
Having a storage device or usb memory stick would only be handy if it serves its major purpose which is storage, a hard drive with 128mb can only store 25 songs on the average. But it totally depends if your storage purpose is only for files such as word documents or pictures but still 128mb is very low.
Wassup Max, I believe I will help you in solving this question. The flash drive 303b is really important especially in windows in that it stores the drivers for windows 7 and the installation guide for the windows drivers. It will note the damaged drivers in the archives. It has a driver scanner which is completely fundamental for windows update- It automatically tracks down and upgrades all the malfunctioning drivers at regular time intervals.
It has a high speed and overall performance as well as driver responsibility which is sustaining an up to date driver.
It preserves the most upgraded variations of drivers in a computer. The 128mb storage is small indeed but it is very efficient in storing of drivers important to the computer.
I hope this helps
Thanks and regards
