Can you suggest some tips to make my Laptop much Faster?
Hi I love to play Games in pc. In the visiting time I also try to play with my laptop. But it can't run fluently, and bother myself. Is this possible to make my laptop faster?
Hmmm first you need to check games minimum requirement before install to your Pc (Laptop). Now I am going to share some basic tips which can make your PC (Laptop) faster. Look at below:
1. Add additional RAMs.
2. Disable unnecessary applications from auto run list (you need to be sure before disabling any application, it can be any system application.)
3. Exchange your HDD with any 7200rpm (read per minute) HDD. 7200rpm is good for gaming.
4. Clear junk files regularly.
I hope this will help you.
You want to play games. For this reason, your hardware must be gaming compatible. But your pc is slow.
* Delete unused files and registries. There are some pc cleaning software to perform this work.
* Defrag your HDD.
* Try to upgrade your pc into a fast and gaming compatible series.
* Scan your pc for virus.
But first of all, be sure that your laptop's hardware are compatible for playing games. Then try to resolve software troubles.
You can make your laptop faster by updating its hardware. (This has a high limitation cost.)
–  You can increase your RAM memory (from 1GB to 2GB).
–  You can update your Processor to some limit.
–  You can update your hard drive (if your hard disk is full, this will cause your computer to slow down).
Or, you can clean your computer.
–  Right click on c drive — > properties — > Disk clean up.
–  Remove your Startup programs.
–  Remove unwanted programs.Â
Hi Sarwar,
I hope this answer will satisfies you.
Dear if you want to make your laptop fast then take a look on these things and act as i suggest.
First you should have to improve your hardware profile, means that you have to upgrade your computer hardware wise like upgrade RAM, CPU etc.
After that,
you have to clean your system for unnecessary files, registry files, Hard disk should be out of bad clusters and bad sectors, install best antivirus to remove all viruses and spy ware.
Clean all temp files specially clean all prefetch files.
And remove all unnecessary software from start up.
And uninstall more graphical and heavy software from your system
Then restart your computer. And enjoy
