Trevor Jhon
40 points
Posted on - 10/28/2012
Hi TechyV,
Can you teach me on how to use get data? Data recovery software that will enable to repair corrupted files and even recover a lost email. A proper usage of each software is very important to avoid any problem in the near future. I am hoping for your kind consideration and help as well.
Can you teach me on how to use getdata?
GetData was a software installed in our computer that can help us recover and restore our files that we cant find and also corrupted files. First in order to use it you must need to have this software installed first in your pc. Install your Getdata software using the installation wizard so you can select the best option regarding your problem. If possible do not install the software on the driver of your deleted or corrupted files or you can remove your hard drive and install it as a secondary drive on a different computer, then install Recover My Files on the other computer's primary drive.
This will eliminate or reduce the possibility of overwritten files and if this thing happen you cant recover it open the Recover My Files and search for your deleted files. Click the recover button on the toolbar and then you can search all the possible drives your file was stored then click Next.
Select a search option. GetData recommends selecting the "Search for delete files" option first. If you are unable to find your files with this search option, return to the search setup and select "Search for deleted files , then search for "Lost File" types." Click "Next" to continue.
Select the files, folders, or groups of files and folders shown in the search results that you would like to be recovered and saved. To select a single file or folder, click the box next to the name of the file or folder to be saved. To select more than one individual file or folder, hold down the control (CTRL) key on your keyboard when clicking multiple files or folders. To select a group of files, hold down the shift key on your keyboard and click the first and last files in the group. Now you can pick where to save your files. After using it then you can close the program.
