Can you tell how different does Piriform logo icons from other software?
I'd been curious about Piriform software. They say that logo icons are very user friendly. How can you say that the Piriform logo icon differs from other software?
Piriform is a company that produces software for both Mac and Windows operating systems. Their products focus mainly on your computer system's cleaning and maintenance. Their most popular products are Ccleaner, a tool used to fix registries, clear junk or unwanted files and Defraggler, a software used for file, folder and drive defragment.
Hey Lhonmar,
Piriform is an English company that creates software for both Mac and Microsoft OS. They are famous for their software being user friendly and easy to use; in other words for non-technological users. They concentrate on defragmentation, Cleaning and Recovering.
I would always recommend you using stock software depending on your OS, but if you insist on using Piriform, go to their website and check out the download section.
