Can you tell me a good photo software for Nokia N8 Symbian
Hello Timothy!
Fortunately, there are a lot of photo editing applications that you can use on your Symbian and are easy to use, so don't worry.
One of the most downloaded is Photo Effect. With it, you can edit the photos taken with the phone's camera. You have plenty of filters and effects to use, together with borders and other options. The downside is that you can't edit other photos from your gallery, but since you said you want to use it on the phone's images, this might be what you're looking for.
Another application is Photofunia. This also has a lot of effects, around 150, and with it you can create designs using your photos. It has an easy to use interface, so it would be a pleasure to use it, especially if you're a photography lover.
So here are your choices, you may pick one of them or you may pick both, since both are free to use and download. Whatever you choose, enjoy the apps and have fun!
Hello Timothy D Washington,
If you want to try the best free photo editing software for your Nokia N8, try snap studio. It is completely free and is a powerful photo editor to meet your needs. With no fuss, it is very easy to use and edit. It is piled with many beautiful sets of effects an filters, Grey scale, Viz color, sepia, oil paint, embossed sketch and anything you need. And share them directly to your social media networks. And believe me you don't need to be a pro!
The Nokia N8 is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA. It was announced to the public on April 2010 and released on October 2010 measuring 113.5 x 59.1 x 12.9 millimeters and weighing 135 grams. It uses mini-SIM card. It has AMOLED capacitive touchscreen display with 16M colors at 360 x 640 pixels screen resolution.
Nokia N8
It supports multi-touch protected with Corning Gorilla Glass. It ships with Symbian^3 mobile operating system upgradable to Nokia Belle Refresh powered by 680 MHz ARM 11 processor and Broadcom BCM2727 GPU. It supports microSD expandable up to 32 GB. It runs on 256 MB RAM with 16 GB internal storage and 512 MB ROM.
The primary camera supports 12 megapixels with 1/1.83″ sensor size featuring Carl Zeiss optics, Xenon flash, autofocus, face detection, geo-tagging, and ND filter. It supports 720p video recording at 25 fps and 720p at 30 fps (via SW update). It has secondary VGA videocall camera.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic, Wi-Fi 802.11 b/g/n with UPnP technology support, Bluetooth 3.0 with A2DP support, GPS with A-GPS and Ovi Maps 3.0 support, stereo FM radio with RDS and FM transmitter support, and microUSB 2.0 with USB Host support. It has built-in accelerometer, proximity, and compass sensors.
The preinstalled web browser supports WAP 2.0/xHTML and HTML with Adobe Flash Lite support. Java is supported via MIDP 2.1. It runs on non-removable BL-4D Li-Ion 1200 mAh battery with standby time up to 390 hours on 2G and 400 hours on 3G. Talk time is up to 12 hours on 2G and 5 hours 50 minutes on 3G.
It is available in orange, pink, dark grey, silver white, bronze, green, and blue colors.
1....
