Can Zonealarm removal tool remove all data of previous antivirus?
I'm thinking of uninstalling my Avast antivirus then install the ZoneAlarm antivirus. Can the ZoneAlarm removal tool remove all data and components of the previous antivirus? I'm on Windows 7 64 bit. Any help would be appreciated. Thank you.
