Cannot access my Gmail account
There is many problem in Google mail(gmail). Sometimes Google is creating so much problem like this. You have to apply 2 or more times to access your gmail(google mail account). Gmail is a good mailing service. It is increasing its facilities. So, many problem occur. You should restart your net connection and browser and try it. If it is not worked then there is a option of "I can't access my account". Click on the option and follow the steps to access your gmail id/account. 1st you have to put down your email address then a captcha image and you may have to give a security question answer or alternative email or phone code. Then your email will be able to access.
Hi,Diego58, your problem is most probably due to the internet connectivity or the password. Did you forget your password. You need to specify the error, if the error is on the password, then you may need to reset by clicking on the 'Can't access your account.' Input your email address or Gmail username and you will be sent a new password.
This will send your new password and you can be able to login with the password. Hope this helps, thanks
