t.andy
20 points
Posted on - 12/26/2011
Hi All,
In a server no matter what exe i click i get the below error
D:SQLServer2005-KB970892-x86-ENU.exe
"C:Documents and SettingsOwnerLocaI SettingsTemporary Internet FilesContent.IE5WLIAA7…
Windows cannot access the specified device, path, or file. You may not have the appropriate permissions to access the item.
OK"
Thanks a lot for the help
As usual love techyv experts help
MarkT
Cannot access the specified device, path or file on running exe file
Hello T.Andy,
Without providing the specific Operating System Name, I will assume that you are running a Windows Server 2003.
Internet Explorer Advanced Security Configuration is the one that causes this error. So, you should uninstall it.
SOLUTION
1. Go to Control Panel
2. Click Add or Remove Programs
3. Under Currently Installed Programs, select the Internet Explorer Advanced Security Configuration. (refer to the picture below)
4. Uncheck it.
5. Wait for it to finish
6. Restart the machine
7. Done!
t.andy
20 points
You are a genius . Really helped a lot.
great help mate
MarkT
It's my pleasure. If you have more questions just ask. We are always ready to serve you!
Best regards!
Besides this solution you can apply another techniques too to fix this problem . It looks you have a malware activity in your PC. First analyze what happening in your PC, to do that just go to task manager (Ctrl + Alt + Del) then click on processes tab and check the processes running on your PC. Visit this Techyv post which one also will be helpful to resolve this issue.
Windows XP Permission Error: Windows cannot access the specified …
