dynatec
10 points
Posted on - 02/09/2012
Hi.
I want to install MS Office Professional 2010 RTM (Released to Manufacturing), using the Volume Licensing Service Center (VLSC) and Multiple Activation Key (MAK). I got the product.exe from a person in Microsoft. Sadly, I can’t activate the key when I went with the installation, and I get an error message that says the key is not valid.
I need help. Thanks a lot.
Cannot activate key during MS Office 2010 installation
Hi Dynamec
I think that you’re having a problem during your activation of your MS office 2010, due to miss encode or it’s already reach the maximum user that can use for this Product Key. There is another solution of your problem, just call the customer service of Microsoft and they will ask your Ms Office 2010 Product key.
Hope this will help you on your problem.
If the file product.exe that you got from someone who is possibly working in Microsoft and it doesn’t work anymore saying that it is an invalid key, then that person possibly gave you the wrong activation file. But if that is the only file that is being used as a Multiple Activation Key, then you may need to request your activation code from Microsoft again. Since the file is already not working.
Or you can search the web for any serial code for Microsoft Office Professional 2010 RTM, if it is possible to find one. Just be careful when downloading something from different websites. Scan them first after being downloaded.
If you currently have a legal copy of a program installed but you have lost your CD key, try a free product key finder program. This is a perfectly legal way of obtaining a product key because it's the same once you purchased when you first installed the program.
dynatec
10 points
Thanks a lot to all of you that you have tried to give me a solution. Your solutions helped me a lot. Thanks techyv also. I am grateful to all of you.
Hi  Asifrehman20
Thank you so much.. It was really a great help to use the Product Key Finder even I got a problem of losing such data during installation and I have searched a lot of related issues regarding this… this was the link I tried hope this will help.. don't forget to scan before downloading any files…(i agree on this )
(Windows Product Key Finder Professional is a software utility which allows you to find and recover your CD Product key for Windows or Office programs for the purposes of reinstalling / repairing your Windows or Office setup)
thanks a lot….
