While sending an email, I want to attach a PDF document with it but whenever I try to do so I get the following message:
Error
The action you tried to perform couldn't be completed
because there’s a configuration problem on the server.
If the problem continues, contact your helpdesk.
Close
I even tried to attach any other kind of a file but even then the same message appears. The message says that it has some kind of a configuration problem with the server. Is anybody facing this kind of a problem?
Please do help me in this regard. I'll be grateful.
Regards
John
Cannot add attachments in Email
Hello Alex,
Check if you have got a host name configured in IIS under the bindings.
On your computer, go to CAS and then open up the IIS Manager.
After that go to the Default Web Site and in the Actions Pane, click on bindings.
You will need to ensure that there is no host name that has been configured.
In case there is one, you will need to get rid of it.
And then login to OWA and then try deleting and moving the items again.
In MS Exchange, EWS could be sed on the server-side to delete items or them to different folders. In case there a host header that has been configured, then will not be able to EWS on the server-side that causes the error to occur.
Carl
