Cannot add a watermark in Adobe Acrobat
When I want to add a watermark in Adobe Acrobat a window with Import this Action appear and I press the Ok Button and I press it. After that this error message appears and I have to add the watermark again. When add it again, still the same error. Now does anyone knows how to fix and how can I add a watermark to my documents ?
Thanks !
Adobe Acrobat
The source file you specified could not be found. Please try again.
