Cannot burn discs with my Nero test drive
Hello, my Nero test drive is giving me a problem with an error code 030C00 whenever I am trying to burn discs. I searched for solutions in the internet but I couldn’t find any. What steps should I take in order to make this work? Can you give me any information about how to solve this problem? Thanks.
Answered By 0 points N/A #149535
Hello there,
                Well did you tried this with another disc? Is it the same problem with each and every discs? If its the same problem with each and every disc you better go to nero.com and download some tools there along with Nero Disc speed. Then run it and create tests on one disc and check if you get errors. Also are you using a trial version? If its a trial version then kindly get the upgraded version with license and check. Also check with your writer is it copying the files properly.
Hope this helps. Good Luck!
