alexascott
Posted on - 02/21/2012
Hello
Firstly my primary problem was resolved on Sunday by Ashley Robinson who gave all the replies. So she earns a BIG, BIG THANK YOU!!!!
Now yesterday when I wanted to save my Topaz changes in either regulate or Clean2, I got the following things:
"Proc Engine: error code:-1000"
I clicked OK only to get this:
Could not complete the Topaz Clean2 command because -Proc Engine error"
Why is that occurring? Need your help to solve this.
Thanks a lot.
Cannot complete the Topaz Clean2 command
These error messages are also often related to memory and the size of image. As a test process, you can try using a smaller image and see if you still get those error messages.
After doing that you also need to follow the procedure below:-
Always be sure that you are using the latest version of Topaz. You can get it easily online at this URL https://www.topazlabs.com/downloads
Also try reducing the amount of memory that Photoshop is allowed to use down to just about 70% only.
Restarting your PC and closing any other additional programs or any such images not in use will also paves more memory.
OR
Try increasing your virtual memory to more than 4 gb (if you have that much space)
