Cannot connect to Cyberghost VPN (related to Kaspersky Anti-Virus)
As part of my routine, I start up my laptop and run Cyberghost VPN.
When I was about to install Kaspersky Anti-Virus 2012 on my system, an error message prompted me.
The error message says:
It is currently not possible to connect to the CyberGhost VPN network.
Check your firewall settings and make sure that you have an active
Internet connection.
Error:
Internet connection
Thereafter, I encountered another bubble message via task-bar saying that my security programs are set as off.
Furthermore, I was not able to report the issue to Kaspersky technical team for the reason that of the volume is about 300Mb. My Internet speed would take me lots of hours to fully accomplish the reporting. The following are the specifications of my system:
– Windows 7 Ultimate x64
– Kaspersky Anti-Virus 2012
– No firewall enabled, and no other security applications are installed.
Do any of you have any idea to resolve this issue?
