Cannot connect to Login Server-time Error
Hello SF players,
Today I opened Special Force game application, and I get this error that says I cannot connect to login the server.
I am sure one of you have experienced this kind of problem. I need to know what causes this.
Help is hard for those who don't ask.
Thank you if one of can help me.
Notice
Cannot connect to the Login Server – Time Error
Best Answer by jakia01
Answered By 0 points N/A #123828
Hey,
Is your Internet connection available in your local area connection. at first check out. because of  connection problem sometime shown this kind of problem. Your internet connection provider network settings.
I want to say all the terms of network and connection will be alright. you may get one solution. If you work in another website then it is very common that your connection working.
Next select another browser it will prove you that browser you worked before was run or terminated. If the browser being alright then search again in same address sometimes the selected server would not work.
Try again by above discussion.
Try install again and make sure the bookmarks address available on you.
thanks
Answered By 0 points N/A #196780
This is quite a knows issue in which McAfee blocks SF from starting.
So what you can do is that You can uninstall McAfee antivirus and use some other antivirus instead. Reboot your computer and the game should be working fine. Or you can reinstall the game and check back if you are receiving such error yet again.
