Cannot connect Moto 360 to my new Moto X phone.
I bought a Moto X smartphone to use together with my Moto 360. When I try to connect the two, however, I cannot get past the “Choose a device” screen in Android Wear. What could be the issue? The Moto 360 has never been connected to another phone, and the Moto X is brand new.
Best Answer by Mmasi Whitney
Answered By 0 points N/A #180971
Open setting then click security after that press trusted devices then enter your pin
After turn on trusted devices with top right slider and then you will able to your desired phone
And before all that first pair the device then try .
Answered By 0 points N/A #180972
Hi Matthew,
If your Moto 360 won’t pair with your phone, try the following troubleshooting solutions:this pairing will be possible only in Android 4.3 or above so first Check that your phone or tablet is suitable for it. You can visit g.co/WearCheck from your phone to check compatibility. Your phone should be next to your Moto 360. Bluetooth should be kept in on condition. Check your phone's Internet connection is on and connectivity is good. Try opening a website on your phone, such as news.google.com to make sure you are connected. make sure that the following apps of your phone are up to date :
        Google Play Services app version 5.0.77 or above
        Google Search app version 3.5.12 or above
        Android Wear app version 1.0 or above
Restart your watch it can be done by  holding down the power button until it turns back on.
Thanks,
Lee Kevin
