Hi experts!
I have installed and deployed Web Parts to the "My Sites" part of Sharepoint. After inputting my Yammer email ID and password in the consumer fields, I got the following errors while trying to connect:
Error in OnPreRender()
Error retrieving web response Unable to connect to the remote server
I can't do anything else at this time! I also can't see the remaining error concerning remote server as I receive a Javascript error. Please help.
Cannot connect to Sharepoint after inputting my Yammer credentials
Hi
The error looks like that there is an error in the connection you have made through the SharePoint. The error is not quite obvious and seems that you have entered and connected it properly so the option you have for now is that:
1. Uninstall you MS share point and then install the software again and then check hope this problem will resolve or
2. Put some other email Id or make another login and try then if still this problem occurs then go to the settings and make the settings default and then try your email id it will work if still it does not work then install the software again this is the only choice you have.
Hope you will find the best way from both of the above options.
