A K Azad
35 points
Posted on - 03/22/2013
When I setup a windows backup i get this error Cannot create a file when that file already exists. (0x800700B7)
Here is the screenshot
Configure Backup Send Feedback
The specified network location cannot be used
Verify the path points to a correct network location and that the supplied credentials can be used for write access to the folder.
Hide Details Close
Thanks
Cannot create a file when that file already exists. (0x800700B7) backing up
Hello
Follow these steps :
1 – Create a new user account with admin. permission and make password
2 – Disable the firewall
3 – Give full permission to the disk you want to shared /backup it
If this solution will not solve this problem try to do the following :
– Open Run
– Write (secpol.msc) and hit enter
– Choose Local Policies > Security Options
– Find( Network Security: LAN Manager authentication level)
– Change the settings to ( Network Security: LAN Manager authentication level )
I hope your problem will be solved
