Cannot Create File: Error on Linux Server
i am using one linux server and that is connected with some aix server through network .when I give one of the command to extract some file I am getting error as “./sbin/metaimport: cannot create file: Not a directory” I tried checking in the filesystem but I am not able to find out the error.would someone can solve the problem
Answered By 0 points N/A #80419
when you connect some server and want to share some files with other through network you should give access to each server .for that you need to check the hostname whichever connected and give the permissions to share each data.go to one of the server and give the command cat /etc/hostname there you will see some hostname and the ip address of server connected.the server which you want to connect ip address or hostname should be added there.so foe both the server you should add the host name and ip address.so here above error you are getting is due to the file system not added to the host destination.source server and sestination server should give equal access so that you can share the data or the filsystem.
