teamslader
10 points
Posted on - 04/14/2015
I can not decide between Android Lollipop 5.0 and iOS 8 , which one should I buy ? I really need to buy a new phone and I need a reliable system for work that does not freeze and crash often and is also fast , can anyone shed some light on this matter ?
Cannot decide between Android Lollipop 5.0 and iOS 8
Android Lollipop 5.0 and iOS 8 are two different operating systems. Each of them has its own strength as well as associated problems. It all depends on what you would want to do with the phone. I would want you to do a bit of research based on what you want to do with the phone.
Find the strength of the Android Lollipop 5.0 and that of iOS 8.
Find the problems associated with Android Lollipop 5.0 and that of iOS 8.
You can now choose the operating system that will help you achieve what you want to do with the phone.
